2006-07-17 11:06 PM - last edited on 2022-04-09 11:17 PM by Karl Ottenstein
2008-04-30 12:51 AM
Jill wrote:Has anyone taken the time to teach you how to use it properly?
I switched to ArchiCAD about year and a half ago, and still find the offset tool cumbersome. It seems to me that the point of view of previous AutoCAD users is not being given fair consideration.
2008-04-30 12:53 AM
Laura wrote:Nor does "different" always mean "better."Jill wrote:True, but the poll results are very telling as well. I think that most AC users' point of view is that "different" does not mean that it's "not as good."
I appreciate the humor, and not to sound overly sensitive...but if there is a way to improve a tool, why not do it? And the over 13,000 views of this topic demonstrate it's a valid point.
2008-04-30 01:12 AM
TomWaltz wrote:(Yes -- but I prefer the double negative
2008-04-30 03:34 PM
TomWaltz wrote:No, it's a small firm and I have to teach myself -and the others. I rely on ArchiCAD help, The Reference Guide, and this forum for information. I'm trying to push us forward with using BIM better, but we aren't pros yet -and I do still miss the AutoCAD offset tool -can't help it...just being honest...even though that apparently makes me a little backward.Jill wrote:Has anyone taken the time to teach you how to use it properly?
I found a manual transmission cumbersome until someone taught me how to use a clutch.
2008-04-30 04:08 PM
2008-04-30 04:19 PM
another Moderator
2008-04-30 04:37 PM
ejrolon wrote:Fine if the wall you're copying is parallel to or at right angles to the grid. Otherwise you have to reset the grid first - and reset it afterwards. So that's an extra 3 clicks before you even count those you need for the offset command. This is where the Autocad command scores.
-I need a wall here
-place wall
-edit settings of wall (height+width+materials) minimum settings you know at that point
-fix length
-drag a copy of the wall to next position
-connect a wall from the first one to the second one
ejrolon wrote:The 'intersect' command matches 'fillet', and I've found no better way for tidying up wall intersections.
Autocad commands that you will/may be using less or in a different way are;
-fillet
-stretch
-extend
-offset
-Lines
2008-04-30 04:48 PM
another Moderator
2008-04-30 06:56 PM
2008-05-01 02:10 AM
ejrolon wrote:You don't even need to wait for guidelines :
Keith,
That is what AC automatic guidelines are for, no need to reset the grid.
Select the Wall
type shortcut for "Drag a copy"
Hover mouse over previous wall -until guideline shows up
Move mouse in direction you want
type the distance
__
Works with Array too
