2024 Technology Preview Program
Wishes
Open / Edit / Cut (at Point/local) closed Polyline Facades
Romans
Please provide a method to open/cut polygonal (closed) facades.
Thanks.
Apple iMac Pro with macOS Sonoma, AC 5.0 to 27 INT and GER, all the latest
2 REPLIES 2
runxel
Legend
That's already working, but quite counterintuitive.
There is a seperate command for splitting curtain walls ("facades").
However, you will need another (dummy) curtain wall.
So:
Draw the dummy CW.
Select the CW to split.
Use the dedicated CW-split command.
Now select the dummy CW. This will be the place where your main curtain wall is cut.
Works with closed CWs as well.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Romans
Thank you.
It is a little quirky that a CW only can be split by another (dummy) CW.
Also, the split does not happen only at the location, all CW-parts inline with the splitting CW will be cut.
See also the image attached.
So therefore it would be great to get this function improved.
