2024-03-04 12:13 AM
It should be possible to relink a drawing by dragging and dropping a view to the drawing frame so that we can use the the navigator instead of going through the context menu to a dialog with the same structure but that resets between relinking multiple drawings.
2024-03-04 10:23 AM
So just to clarify.
You don't want to simply delete the existing drawing and then drag & drop the new view on the layout.
Because you will have to resize the frame and re-position it?
You want to keep the existing drawing frame and have the new view just link to it by dragging a view from the view map to it - although you would probably still need to resize it unless they were exactly the same size.
Barry
2024-03-04 07:48 PM
The use case would be the same as for the current "link to" functionality - it would just be a quicker and more intuitive way to do it.
