Currently there are limitations in available data selections depending on which tool you're using.
Not only in the interactive schedule, library part parameters should be available in the expression editor, find & select, autotext label and in the graphic override criteria as well.
Same way, IFC properties should be available in the expression editor and in the GO criteria as well.
We should have the same data access from everywhere.
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 27 JPN USA & INT | Windows 10
