2015-04-03 01:12 AM
2015-04-15 03:51 AM
Vahur wrote:Sorry I got that from the Help guide for what ever version of Archicad I had open at the time (can't remember which one it was now).Barry wrote:There is no such menu at this location, tried all profiles, including standard.
Not if you don't want it to.
Turn off the Auto ID Increase checkbox in the Options > Project Preferences > Miscellaneous dialog box.
2015-04-15 04:09 PM
Barry wrote:Barry, You are absolutety right.Vahur wrote:True but if you have the type parameter in your door/window objects you can create a schedule that shows that parameter.
There is no way to change properties of elements by changing favorites.
It can then be edited directly in the schedule.
You can even use the schedules as an advanced Find & Select.
Set up a schedule to find all windows that are - 1400x1200, opening inside, white colour, triple glass - use these as your search criteria.
Add a field that shows the 'Type' parameter and then you can edit them all to be the code that you want - either directly in the schedule (one by one) or you can highlight all of the windows in the schedule and use the 'show and select in plan or 3D' buttons to select all the windows and edit the parameter at once for all selected windows.
Now you can just change the selection criteria to find other window types.
Not the most elegant solution but until we get the option to Find & Select by object parameters this will have to do.
2015-05-20 02:57 AM
2017-08-07 05:42 PM
2018-01-25 05:54 PM
2018-01-29 03:47 AM
furtonb wrote:Not as far as I am aware of.
is it possible to access Properties from the GDL Script?
2018-01-30 12:36 AM
Barry wrote:Sad. Thanks for the info, Barry!
