Suggestion to help quickly see (from the View Map) whether Saved Views, are following:
- "By the Project Map" ID & Name or
- if they have been Customised
If the ID or Name were following 'By Project Map', it should be greyed out in the 'Properties' tab that shows the View Settings - currently it always shows as editable (image 01)
Currently you can only see if the ID or Name is following the Project Map through the View Settings dialog (image 02).
![01-View Map ID & Name.jpg 01-View Map ID & Name.jpg](/t5/image/serverpage/image-id/59562i5ED45103BB8EC352/image-size/medium?v=v2&px=400)
![02-View Settings.jpg 02-View Settings.jpg](/t5/image/serverpage/image-id/59563i1EB89FC29D22092E/image-size/large?v=v2&px=999)
Graphisoft Certified ArchiCAD BIM Manager
ArchiCAD 27
Windows 11
