2006-11-29 05:11 PM
2006-12-04 06:47 PM
Dan wrote:Pull in the labeled elevations from the module into the layouts.Ray wrote:Ray,
...Sorry, Dan yes in plan, but I was thinking specifically of labelling doors and windows in elevations, and as the elevations can not be part of the module then I can't see any way of achieving this.
I guess you're right...you can't label in elevation if its a module...you would need to break the hotlink.
Dan K
2006-12-04 07:28 PM
Djordje wrote:Djordje,
...Pull in the labeled elevations from the module into the layouts.
2006-12-06 05:30 AM
Dan wrote:If everything is labelled in the module file, you can pull the elevation views from the modules into the layouts of the master file. Provided, of course, that the modules are spearate buildings and that each one has its own file, sully documented.Djordje wrote:Djordje,
Can you explain what you mean by this?
Dan K
2006-12-06 06:30 AM
2006-12-06 03:24 PM
TomWaltz wrote:Tom,
...My complaints with the Door/Window Dimension Markers (that are built into the doors/windows) are that they are generally really hard to control, cannot be shown in elevations, and must use display options to be controlled. I prefer being able to use layers and to be able to easily drag/rotate the symbol without digging for parameters or hunting for the hotspot.
2009-09-15 09:20 AM
2009-09-15 01:12 PM
2009-09-15 02:44 PM
Gerald wrote:I think the main problem here is that Section/Elevation etc. Viewpoints do not come through from a Module.
I’m really quite surprised that it’s not possible to label model components from hotlinked modules in elevation or section (in my case today, windows & doors, but just as equally, I’d like to be able to label walls etc..)
I'm also VERY surprised this topic hasn't had more interest, and the whole subject of addressing such a major omission seems to have been forgotten.
To the Moderator: is there any later discussion of this? My searches only turn up this thread
I understand that the hotlink brings through model data, but for some reason, not labels. Presumably because they’re not 3D, but then that doesn’t figure because 2D PLAN elements come through.
I’d like to see this ESSENTIAL part of BIM documentation implemented as soon as possible, for obvious reasons: Imagine me having to individually identify, co-ordinate and then label about 300 different windows over a block of attached town houses, which have been assembled in a ‘main file’ in the usual way.
Plan markers are great, but perhaps the ‘label system’ needs re-visiting to allow these invaluable identifiers to be used to their full extent in documenting a project.
Seems this one fell off the “to-do” list… or into the “too hard” basket perhaps? Surely it’s not that hard.
Come on Graphisoft – get with the program and provide the fundamentals of an intelligent BIM documentation environment. I’m sure I’m not the only one who winces every time we have to label a few hundred doors in a hotlink-rich project.
2009-09-15 03:02 PM
laszlonagy wrote:The main problem is very clear, but no-one is offering a solution. If there is a label / marker out there that can be linked to a door/window etc. please include a link/reference in this thread to help all those users whom my comments undoubtedly represent.
And since those Labels are elements within those Elevation Viewpoints, they do not come through.
I think this is a (currently) (inherent?) limitation of the Modules concept.
2009-09-29 09:58 PM
