2023-06-16 08:09 PM - last edited on 2023-06-16 08:41 PM by Karl Ottenstein
Associate a window/door etc. with two or more walls. Image in Attachment.
Thank you.
2023-06-16 08:42 PM
This has been on the wishlist for years. I'm surprised it isn't on the roadmap.
2023-06-18 10:48 AM
And if may add to that, It should behave like an opening tool, meaning it can affect Hotlink modules.
2023-06-19 03:24 AM
Valid (long time) wish, and hopefully one day the window tool will be like the opening tool where it can be associated to more than just one wall.
Or the door/ window and opening tools will be amalgamated.
Just in case you or anyone reading aren't aware of the options, they are...
Add a separate empty window (or opening) in the other wall - you will have to adjust both separately if your window changes.
If it is the same wall type, just make a single multi-storey wall - then you need just the one window.
If the walls are separate profiles you can merge them into a single complex profile wall and again you will only need the one window.
3 weeks ago
I completely agree. The easiest solution would be for windows, doors, skylights, etc. to function as an opening tool, as this would enable some additional functionalities.
If we had this functionality, we could:
3 weeks ago
But why are the walls on top of each other? Maybe you can split the walls vertically instead of horizontally to position the window.
2 weeks ago
WE NEED SKIN DESIGN in Archicad!!
yesterday
half-height something applied on a facade, happens a lot. If the window/door had an option like "openings" to interact with something else, that'd be awesome. (Event to a slab/ ceiling, regarding the tracks that touch the floor)
