3 weeks ago
Guys,
I would like to suggest moving the building material priority number from the building material tab to the design tool tab.
This way it is not necessary to make duplicates of materials just to have weak / medium / strong material i.e. insulation weak / insulation medium / insuliation strong / brick red 1 / brick red 2 / brick red 3 etc.
if you move this priority to the design tool settings you will be able easily create 3d details the way it meant to be. without using duplicates of materials, without using solid element operations or other weird workarounds.
give a like 😄 if you like it.
