2004-02-16 09:59 AM
2004-03-12 11:37 AM
"Laci Neda" wrote:
You are very optimistic
Ok AC99, Ill be dead before...
Maybe you noticed the topic is the hottest actually in wish topic, might be some good reasons...STMK deserve AC, sure most of us prefer having a very simple but accurate tool rapidly rather that waiting for the holly grail.
2004-03-12 05:59 PM
Laci wrote:Actually, there's a new? code issue that would be helpful if Stairmaker could address. I've noticed it in IRC 2003, namely the requirement that all treads have a minimum dimension (6 inches - comes into play at winders). It would be nice if Stairmaker would allow you to enter some of these parameters, and maybe also allow for a generic layout for quick schematic design. The current treament at winders/corners is probably one that's been giving me the most headaches so far.
...if you have more to contribute on this topic, details that have not been touched before, please do so. I'll be listening.
Laci
2004-03-13 12:03 AM
Sergio wrote:Perfect sense. Many US stairs have landings with 0" offsets. This has been one of the biggest problems with using StairMaker on residential projects (aside from the largely useless handrail selection).
BTW, an option with 0 inches at the winder would also help when drawing existing conditions.
(hope this makes sense).
2004-03-17 03:24 AM
2004-03-17 04:24 AM
2004-03-17 04:36 AM
Daniel wrote:Maybe it's just me, but whenever I ask it to turn off the handrails, the side with the handrails "off" still shows through almost like a sheet of glass. And if I'm pulling a section or elevation that happens to include the stair, I see it also. I must've missed a trick.
... You can even now just leave the handrails off the stair and insert a 3rd party handrail to better suit your needs.
2004-03-17 09:33 AM
2004-03-20 07:56 AM
"Sergio wrote:
....that stair looks great. How did you get the treads to come to a point like that? Whenever I try it out, it tells me there's problems with the stair and I'm at a loss for which option(s) to adjust. It's probably my biggest source of frustration in AC.
2004-03-20 07:57 AM
2005-07-08 12:56 AM
