BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx PRO
Aaron Bourgoin
what's up with Lachmi Khemlani getting the scoop on something called BIMx PRO.
What is it and what is the upgrade path from BIMx Docs?
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
46 REPLIES 46
Eduardo Rolon
I knew that I would be able to trip you…
Now you owe me a beer in about 3 weeks
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
not so fast. but still that's okay by me.
Jared Banks, AIA
Shoegnome Architects
Erwin Edel
JaredBanks wrote:
okay, here's some info:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/visualization/graphisoft-bim...
ArchiCAD just knows? If you save over the previous file, or merge with it?
I'm still a little confused and very interested in the point Eduardo raises. A project will go through multiple design stages etc, will you have to spend $50 every time you make a new .bimx? Can you use different .pln files of a single project?
By saving over does that mean that you can only have 1 .bimx file? How does this work with archiving your project documentation? Good practice to me dictates that anything being published to leave our office needs to be archived (PDF, DWG, .pla). If BIMx would be part of this documentation flow, it would be part of the archive folders. Will I lose the functionality on old version once I overwrite the original file (and, of course, copy the old file before that)?
Especially during the preliminary stage we will go through a lot of models, variations etc for our large residential (700-2.000 m³) projects. Spending the $50 once would not be a problem, really, but if you would be spending it every time it would be good to know before you get a client impressed by fancy presentation and end up paying that 10-15 times
Even during construction there generally end up being quite a few revisions over the course of the build. Going truly BIM and embracing it as part of communication on the buildsite, it would be good to know that every revision doesn't cost another $50 to re-publish.
Unrelated: we are very much a multi-platform office. Windows workstations, macbooks, iPads, android phones etc is there a way to register a single account to purchase multiplatform or will it be per-platform purchase for the pro version?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I asked the guys at Graphisoft and here is the answer:
The BIMx Hyper Model is identified by the Name of the Publisher Set from which the model is created (this is the same Name the user sees in the Project List in the BIMx app). So the Hyper Model is not identified by the name of the resulting BIMx file. Therefore the name of the saved BIMX file can be freely modified to carry version/design option etc. information, and one does not have to pay the 50 USD each time the name of the BIMx file is different.
This is even true if you saved your Project file under a new name (e.g. in the SD, DD, CD phases) with the name of the Publisher Set staying the same.
Answer from the same Graphisoft source:
Purchases on mobile platforms are platform-dependent, which means that it is not possible to purchase something on the Apple platform and get it credited and use it on the Android platform, and vice versa.
There will be 3 BIMx webinars on March 10 where you will be able to ask any further questions you have:
http://archicad-talk.graphisoft.com/viewtopic.php?t=48393
Erwin Edel
Thanks for your prompt reply Laszlo!
I understand you would buy the apps for different platforms, I'm just a bit confused about the actual model files. The purchase to share a BIMx pro hypermodel is made in the BIMx Pro app? Can it be shared from both apps after paying in one platform version?
www.leloup.nl
From the guys at Graphisoft I received the info that it is planned to make it possible to buy the model access from Android as well in the future and to make the link multiplatform.
But at the moment this is only available on iOS.
DGSketcher
Legend
I'm confused by the app upgrade. I paid for BIMx Docs and I can see the 2D docs with hyperlinks etc but when I go to the Apple store BIMx Pro is listed as a different app to the BIMx one I have installed and I have to pay to install the Pro version. I thought this was just rebranding and not an excuse to take another slice of my hard earned cash?
Your BIMx Docs app should upgrade to BIMx Pro.
If it hasn't happened automatically go into you app updates and do it manually.
DGSketcher
Legend
Thanks for the suggestion Barry. I might be misreading the presence of the two different icons in the app store. I was thinking the icon on my iPad should carry the same "Pro" flash but maybe not as it was upgraded from the free version.
