2020-07-08 09:56 PM
Solved! Go to Solution.
2020-07-13 08:05 PM
2020-07-13 09:14 PM
2020-07-13 10:30 PM
2020-07-14 12:18 PM
2020-09-23 06:41 PM
2020-09-23 11:42 PM
IF ( OR ( LEFT ( {Property:PRODUCT INFO/Library Part Name}, 2 ) = "W1", LEFT ( {Property:PRODUCT INFO/Library Part Name}, 2 ) = "W2", LEFT ( {Property:PRODUCT INFO/Library Part Name}, 2 ) = "W3" ), SPLITRIGHT ( {Property:PRODUCT INFO/Library Part Name}, " ", 2 ), {Property:PRODUCT INFO/Library Part Name} )
LEFT ( {Property:PRODUCT INFO/Library Part Name - Short}, FIND ( "22", {Property:PRODUCT INFO/Library Part Name - Short}, 1 ) - 2 )
2020-10-07 07:43 PM
2020-10-07 10:10 PM
2020-10-10 11:05 PM
IF ( OR ( LEFT ( {Property:PRODUCT INFO/Library Part Name}, 1 ) = "W", LEFT ( {Property:PRODUCT INFO/Library Part Name}, 2 ) = "W1", LEFT ( {Property:PRODUCT INFO/Library Part Name}, 2 ) = "W2", LEFT ( {Property:PRODUCT INFO/Library Part Name}, 2 ) = "W3" ), SPLITRIGHT ( {Property:PRODUCT INFO/Library Part Name}, " ", 2 ), {Property:PRODUCT INFO/Library Part Name} )
2021-02-26 05:24 PM
reidweber wrote:Very simple. Select the window you want to have a different name. Open it, Ctlr+Shift+O, change the name to whatever you want. Closing the dialog box will prompt you to Save. That's it. -- But, while you are at it, you may want to correct the Subtype which is probably Corner Window by default. You might also want to change the Author to your name instead of GRAPHISOFT for the sake of organization. As with saving any object, it will by default be the selection ready for you to place. Now in your Interactive Schedules, the new name of the window can be displayed how you like it. The window with the new name will be in your Embedded Library. To see if it is there, you may want to have the window tool selected, then look for it. Otherwise, you will have to look for it another way because it won't show up. The original window of course remains as it was in the original library.
Is there any option out there for displaying the Library Part Name differently on a window schedule?....
