Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Save As .dwg
rengarch
Is there a dxf/dwg export plugin to save into R14 format for Archicad 9 and 10? My engineer cannot open my dwg because he has version 14.
Thanks in advance.
Rita
Rita MF Eng, AIA
iMac 27" 3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096MB
MAC OSX 10.11.6
Archicad 20
10 REPLIES 10
TomWaltz
I don't believe so. I think Archicad 8.1 was the last version that could save to AutoCAD 14.
In all fairness, I should mention that AutoDesk does not support it any more either (and has not for 2 or 3 years).
Tom Waltz
Eduardo Rolon
Forward this link to your consultant. It is a free plugin for AutoCAD that lets you open any dwg regardles of version in any version of AutoCAD.
www.dwgseries.com/
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Thomas Holm
Thanks Eduardo, that was a good tip!
Djordje, please move this thread to the Data Exchange department!
Djordje
Your wish is my command ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Autodesk provide a freely downloadable utility "DWG True Convert" that translates any AutoCAD or AutoCAD-based drawing file for compatibility with AutoCAD Release 14, AutoCAD 2000, AutoCAD 2000i, AutoCAD 2002, AutoCAD 2004, AutoCAD 2005, AutoCAD 2006, and AutoCAD 2007 versions. The DWG TrueConvert allows conversion of pen widths to lineweights and the addition of page setups.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=6703539
David Pacifico
In AC9 there was in the goodies folder "DXF-DWG 2K In-Out" That you save down to Autocad 12,13,14 and 2000. I havn't tried it to see if works in 10.
I don't see it in the AC10 Goodies
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
rengarch
I tried to load the "DXF-DWG 2K In-Out" add-on into the AC10 Add-on folder and it does not work with AC10. Right now it seems like the only solution is to have the Autocad user download the free translator because AC10 will not export out lower than Autocad 2000
Rita
Rita MF Eng, AIA
MAC OSX 10.11.6
Archicad 20
The Autocad translator is a free standing program. Anyone can download and use it, not just Autocad users.
Eduardo Rolon
Though I have not tried Autodesk's program does it work as a plugin within AutoCAD or as a separate application. The dwgseries one creates a menu in AutoCAD that lets you open the file without having to launch another program.
AC28 US/INT -> AC08
another Moderator
