Corner window on two walls with different thicknesses
bouhmidage
i think it's a strange behaviour from Archicad as i remember i did this before correctly,
Placing corner windows on 2 diffentent walls causes problems in the corner frame, it won't connect even when i check " different wall thickness " and i add the thickness
Any soltion please ?
Archicad 25
Windows 10 professional
7 REPLIES 7
try the other Corner ?
Also, both Window and Walls can be set to Projected instead of Symbolic - ?
Thanks steve for the reply,
It works for walls with the same thickness, but not with different wall thicknesses, Archicad 23
Archicad 25
Like this -  but does not work with 23.  I got it.
bouhmidage
Does this was mentioned in the new features of Archicad 25?
Archicad 25
It works for me in 23 as well.
It could be that his happens with a certain window type.
Something is not quite right. I have been able to generate the anomies a couple of times but I didn't notice it time to find what it was using Ctrl-z.   What window are you using ?
I was able to get it to look correct using some the Bring To Front tool and changed settings to Projected rather than Symbol.  I think it has more to do with getting things to rebuild than the settings changes ?
bouhmidage
I glt it,
It works only when reveal is set to 0, then, i should place my windows on the inner face,
Archicad 25
Lingwisyer
Guru
https://community.graphisoft.com/t5/Wishes-forum/Corner-Window-Differing-Reveal-Depth/m-p/296199
