Edit existing GDL objects to add missing features
Domagoj Lukinic
Hi all,
Is there a way to edit GDL objects in AC 25 to add some missing features that I need?
For example:
I have here "Horizontal Multi-Sash window 25" how ever it does not have a feature to add transom. Is there a way to add the missing  feature in that object?
If there is a way I want to know how.
Thank you in advance!
3 REPLIES 3
Sure, if you know how to script in GDL.
If you don't, forget it.
The Graphisoft doors and windows are very complicated and not something you would want to tackle without a very good knowledge of GDL.
Your other option is to gang two windows together, so one above the other.
Jim Allen
This is on the community wishlist!
It's a basic omission, and to the best of my knowledge (I even rang GS tech support on this) you can only get around it currently using curtain walls.
Archicad 27 UKI | OS X 12.7.1 Monterey
Lingwisyer
Guru
This was from a few years ago, but you could add a transom to the Sliding Folding Multipanel Bifold Door just by toggling the Transom value in the Master Script.
You still need to save it out to your own library, and I do not think I had any issues with it. It might work with your window?
Ling.
ps. Actually, just checked it, and windows do not have the same toggles... and I get a UI stack error when I try to toggle it in the general macro...
Learn and get certified!
