Align drawings in layout
RainV
Hey!
Does anyone have a trick for aligning different drawings in seperate layouts? Or inserting drawings in the center of the layout.
I included a picture for better description. These are two elevation drawings.
Thank you!
AC25 Windows, Europe
David Maudlin
RainV:
One option is to place a Hotspot at a common point (top of gable, grid marker, etc.), then select it and copy it to the other Layout, where it can be used to locate the second drawing on that Layout.
PREVIEW
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
4 REPLIES 4
David Maudlin
RainV:
PREVIEW
Thanks!
Didnt know that hotspot thing.
RainV:
Glad to know that worked for you. Thanks for adding your signature.
Rubia Torres
Hi @RainV ,
You can also trace reference another layout and align the drawings accordingly.
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
