2024-06-28 12:56 PM
I was trying to save some time by making a wall composite. But in section and plan, the window and door opening does not show line thickness as seen in normal wall. Am i doing something wrong? how can i make it work line normal section with proper line weight? Thank you.
Operating system used: Mac Apple Silicon 14 sonoma
Solved! Go to Solution.
2024-06-28 05:05 PM
In the composite settings, there is an option to add end lines to the skins of the wall.
2024-06-28 05:05 PM
2024-06-29 02:52 AM
Beg your pardon, its a complex profile not composite! is there an option for that?
2024-06-29
03:01 AM
2024-06-29
10:12 PM
Found that! corrected it here! the pen number was 1 here. Thank you for the clue .
