We have always used a title block in a section/elevation in our case (never have liked the detail or worksheet tools - plus I don't think they were there when we first started - can't remember).
We have one object that actually draws a number of different configurations of the title block.
We then add this to the master layouts and crop to the part of the title block we want to use.
So one view is used on any size/orientation of page we want.
Very easy to add it to new masters or even directly into a layout if we want to.
Plus being one object we only have to update the client/job details and even the different company logos once in the object and all layouts are instantly updated.
We don't use the Project Info for client/job details but that could be done as well - we have all that in the tile block object.
Also we don't use the Revision Manager yet but I will look into it as we adopt 18. But it is probably something we won't need to use (small residential work).
All revision are simply added to our title block object at present, they show on all sheets and we always publish a complete new set when needed rather than individual pages.
The attached image of our title bocks is all one object - change one you change them all.
