Thursday - last edited Thursday
Hi everyone,
I'm experiencing a strange issue in Archicad 27 INT when publishing Layouts to DWG.
Everything works correctly inside Archicad and in PDF output, but when I publish to DWG, some AutoText fields are not resolved:
At the same time, my custom AutoText fields (project number, address, project stage, etc.) are exported correctly.
I am using Archicad 27 INT, and the entire title block is created on a Worksheet, which is then placed on the Master Layout. Both the system AutoText fields and my custom AutoText fields are located on that Worksheet.
PDFs display all AutoText correctly and the problem only occurs when publishing to DWG, (I am publishing through Publisher).
Has anyone experienced the same issue?
Is this a known limitation of using system AutoText fields inside a Worksheet placed on a Master Layout when publishing to DWG, or could it be related to a Publisher/DWG Translator setting?
Any advice or workaround would be greatly appreciated.
yesterday
When you use that Master Layout in an actual Layout and you open that layout in Archicad, does it appear correct there?
A Master Layout does not have a Layout Name until it is used in a layout.
