Dimension to CENTER of walls
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2007-08-07
08:09 PM
ā2023-05-30
03:21 PM
Rubia Torres
Thank you!!!
Elizabeth
- Labels:
Dimension Tools
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 08:47 PM
Brian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 09:15 PM
Too bad the automatic dimensioning tool doesn't have a setting to measuring by wall centers like it does for column centers. Oh, well, maybe next version...
Elizabeth
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 09:48 PM
Just struck me since I've used center lines for a long time!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 09:57 PM
TomWaltz wrote:This strikes me because I've always heard that contractors prefer center lines.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 10:14 PM
face of stud dimensions rather than offsetting the
layout marks 1 3/4" from the center lines of walls.
Though the plans are less cluttered dimensioning to centers,
I want to make what I design as easy as possible to build
so I use the face of stud method of dimensioning.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 10:47 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-07 11:20 PM
I can think of one context where dimensioning to centers
and laying out centerlines in the field would not be easier
but as easy as the face of stud system and that is
if the walls are steel studs and the bottom plates
have the diamond shaped cutouts that you could
see the centerlines through and could kick the
walls around until the centerlines were centered
in the cutouts.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-08 05:24 AM
Wearing a tool belt what you want in a set of plans, at least in my residential experience is the simplest path to the correct end result with all the information you want an none you don't. That said, laying out a foundation, wall, floor or roof the "out to out" measurements, as Peter described the outside face of framing is what I want. It is information I need and it is simple and complete. Mistakes are more often than not mathematical on a job site........1/4s + 1/2s are bad enough to deal with. You throw in centerlines and the appropriate offsets, for every wall and I already have headache. Just tell me what the outside dimensions are, and then if you're really good to me you'll give me consistent "same side face" on interior walls. The only time I want or will willingly deal with centerlines and the required math is window and door openings.......[the rough opening varies so much from mfg.. to mfg. it only makes sense to figure those on the job. this also reduces the clutter of too many dimensions.
There you have it, one guy's opinion......
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-08-08 06:00 PM
Residential wood framing guys like dimensions to face of stud. Usually dimensioned on one side from the exterior wall through the house so they can just hook the tape and go.
Commercial guys working with metal studs like centerlines they can just line up on top of. Also, the stuff I have worked on the TI goes to the center of the wall which works with the centerline dimension.
But no matter how one contractor tells me he likes to do it the next one will do it differently.
None of which answers the initial question. Yes it is a problem and as far as I know you have to click the end node.
M1 Macbook Pro
