krab-El
Drawing Title
Hello everyone
I have a tricky issue to solve :
I placed one drawing in the layout and I want to show two different scales in the same drawing title. The reason why I do it this way is that sometimes I need to print the layout using different sizes ( A1 size: 1/100, A3 size: 1/200).  Could someone help me to solve this issue?
Thanks for reading.
4 Replies 4
AllanP
Coding of the title would do it,
if the variable "ac_drawingScale" is in the title, that gets auto populated by the program as text i.e. 1:50
if ac_drawingScale # "" then
   !ac_drawingScale has been auto populated
   ax=split(ac_drawingScale,"%n:%n",aax,aay,aaz)
      !ac_drawingScale gets split into aax = 1, aay = ":" aaz = scale, i.e. aaz = 50 as anumber
      if VARTYPE(aaz) = 1 then
          !CHECKS IF aaz is a number variable type
          text2 0,0,"A1: SCALE=1:"+STR(aaz,1,0)+"-----A3: SCALE=1:"+STR(aaz*2,1,0)
           !STR(aaz,1,0) turns number back to text to combine with other text, i.e. "50"
           !STR(aaz*2,1,0) doubles the number and turns number back to text to combine with other text, i.e. "100"
            !output text  A1: SCALE=1:Scale-----A3: SCALE=1:doubleScale
            !i.e.  A1: SCALE=1:50-----A3: SCALE=1:100
      endif
endif
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
krab-El
Thanks for your answer. But I am still confused because I don't know where I should paste the code.
Guru
Unless you do it manually with plain text, you would need to code it into your title object.
File => Libraries & Objects => Open Object by Subtype... => General GDL Object => Documentation Symbol => Drawing Title
Your title should be listed at the above location. BUT, I assume you have not meddled with GDL before, so making the suggested modifications may not be the very practical...
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
krab-El
Ok. Thanks for your contribution.
