File recovery on ios
LubaK
Hello, please help, I was working in the program, the desired file simply disappeared from the tabs, when the program was restarted, it did not offer to restore by autosave, and the file with the same name was only a week old. Tell me, please, is there any chance of restoring it? lost a lot of work((
4 REPLIES 4
If you somehow closed without saving, then no.
If the program cashed then the auto-save should be there.
I have never seen a file close by itself without Archicad crashing.
You say the file is a week old and you have lost a lot of work.
If you have not saved the work as you progressed over that week, then that is your fault.
If you have saved over that one week period (or while you were last working on the file), then the file should be newer.
Maybe you are looking in the wrong folder?
Do a search on your system to see if it has saved somewhere else.
I don't know what this could be, the original poster talks about iOS so it is definitely not Archicad. Maybe it is BIMx, but you can not modify the model in BIMx.
Eduardo Rolon
or it is AI-Bot
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
It is a Ukranian IP address, so let us see if the original poster clarifies their question.
