2023-09-11
05:45 PM
2024-07-10
03:31 PM
Aruzhan Ilaikova
I added a graphic override for NEW STATUS walls, so that any new wall turns a darker gray/black.
How do I prevent the door opening from being that same override color and instead have it white?
So, more like this at the door opening:
Solved! Go to Solution.
2023-09-11 07:33 PM
Within the door settings, I believe this is the setting you want to uncheck
2023-09-11 09:50 PM
Or you just do not override the cover fill of the door/window.
2023-09-11 07:33 PM
2023-09-11 09:50 PM
