Graphic Override - How to not cut through door?
architect
I added a graphic override for NEW STATUS walls, so that any new wall turns a darker gray/black.
How do I prevent the door opening from being that same override color and instead have it white?
So, more like this at the door opening:
2 ACCEPTED SOLUTIONS
JeffH
Within the door settings, I believe this is the setting you want to uncheck
AC24 / AC26 / AC27
Win10
runxel
Hero
Or you just do not override the cover fill of the door/window.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
JeffH
AC24 / AC26 / AC27
Win10
runxel
Hero
