Hiding labels in certain views
To name windows in elevation, I am using labels showing ID.
Is there a way to hide those labels in a particular view? or for specific scales?
Should I use a particular type of label?
Well, a Label element has its own Layer so you can put it on a separate layer and hide that layer in certain Elevation Views, while show it in others.
5 REPLIES 5
Thank you. I didn't notice window labels had their own layer.
Windows Markers, those don't have their own Layers, but Labels, being a separate element type, do.
How would you hide window markers for a specific view?
Erwin Edel
You can hide markers with Model View Options. So make a MVO with hidden markers and save a view using that.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
