2010-02-18
03:30 PM
2023-05-26
02:30 AM
Gordana Radonic
2010-02-18 04:32 PM
2010-02-18 04:57 PM
2010-02-18 05:12 PM
2010-02-18 05:26 PM
2010-02-18 05:32 PM
2010-02-18 05:43 PM
2010-02-18 06:11 PM
allegronea wrote:You use cameras (and camera paths) for this.
Is it possible to make a 3D view for the view map? Similar to the Generic Perspective view from the Project Map?
2010-02-19 02:53 AM
2010-02-19 02:29 PM
allegronea wrote:If you open the Organizer and drag-and-drop a Viewpoint (such as the Floor Plan) from the Project Map directly onto a Layout, you will notice that a View has been created in the process. This because only Views can be placed on Layouts - a Views is a Viewpoint plus stored settings such as Scale, Layer Combination etc.
I understand what you mean, but isn't the fact that I use the view map sort of obvious? Can you even put a drawing in the layout directly from the project map? ....
2010-02-19 02:37 PM
allegronea wrote:Save a View in a View Map which sets all layers visible.
Actually just realized another question if anyone peaks in at this thread again.
If I set up my settings in my view map the way I want, is there a way to prevent all layers from turning off when I return to the project map?
For example if all of my layers are on while I'm working in the project map, and I then click on my view map view which is set to have many layers turned off, is there a way to click back to the project map without the view map settings sticking?
