2012-12-04 11:06 PM - last edited on 2023-05-26 02:28 AM by Gordana Radonic
2012-12-04 11:16 PM
2012-12-04 11:29 PM
2012-12-04 11:36 PM
2012-12-04 11:51 PM
2012-12-05 12:55 AM
2012-12-05 10:42 PM
2012-12-05 10:57 PM
2012-12-06 02:17 AM
Paopao wrote:Once you have your first view placed correctly, Select it, Copy and Paste onto new layout, select the new view and Right-click> Link Drawing to... and select the desired view from the "Link to..." dialogue.
1 - How to import a view that is exactly the same on different layouts so that I do not have to adjust them:
2012-12-06 01:28 PM
Paopao wrote:Select the Drawing Tool (without any drawing selected) and check its default values, these are the values that will be applied when a View is Placed on a Layout. In your case check the Properties > Angle and Frame. Also, in your Work Environment, look at User Preference Schemes > More Options > When Placing models views into Layouts...
Even if I use the trace reference of the masterLayout when I import it always alnds somewhere on the screen with a rotation of 5.13°. The rotation isn't that dramatic: I set it right from the Drawing Selection Setting, what I really can't understand is the import mechanism.
