Line & Color Same / Automatic Selection
cocoloco
I would love the option to create groups for line & color. means if I draw in line XY, it would automatically use color&thickness that I pre-set up. Not that I have to constantly change both and in between. This would save a lot of time.
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
2 ACCEPTED SOLUTIONS
It is not hard to change the pen colour of a line, but if you really need to, you can save line favourites for each pen colour (thickness) that you want.
Then just activate the favourite and the colour/thickness will be set - as well as the line style, arrow ends and other settings.
My image shows "Solid - red -text layer" but shows a black line.
That is because I changed my pen set colour and have not updated the favourites.
And, to add to Barry's example of using Favorites so that you can set up the line/colors that you want... you can quickly switch the line tool to use any visible line (type and color) by using the eyedropper tool.
Update:  To clarify, using the eyedropper tool switches the active tool to whatever you've clicked on... with all of the settings of that element.  So doing an eyedropper on a line will activate the line tool to draw more of that style line.  Doing it to a Wall will activate the wall tool, ready to model more walls with identical settings.  Etc.
One of the forum moderators
4 REPLIES 4
Ok will test that tomorrow as well this would be life changing because I constantly change lines and colors although they are all coupled same (dotted has certain color and straight has certain colors). Didn’t know about favorites so hopefully it’s accessible . Thanks and will give update ☺️
ok I tested this and it Is sufficient! thanks
