cocoloco
Line & Color Same / Automatic Selection
I would love the option to create groups for line & color. means if I draw in line XY, it would automatically use color&thickness that I pre-set up. Not that I have to constantly change both and in between. This would save a lot of time.
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
2 Solutions
It is not hard to change the pen colour of a line, but if you really need to, you can save line favourites for each pen colour (thickness) that you want.
Then just activate the favourite and the colour/thickness will be set - as well as the line style, arrow ends and other settings.
My image shows "Solid - red -text layer" but shows a black line.
That is because I changed my pen set colour and have not updated the favourites.
Go to post
And, to add to Barry's example of using Favorites so that you can set up the line/colors that you want... you can quickly switch the line tool to use any visible line (type and color) by using the eyedropper tool.
Update:  To clarify, using the eyedropper tool switches the active tool to whatever you've clicked on... with all of the settings of that element.  So doing an eyedropper on a line will activate the line tool to draw more of that style line.  Doing it to a Wall will activate the wall tool, ready to model more walls with identical settings.  Etc.
Go to post
4 Replies 4
cocoloco
Ok will test that tomorrow as well this would be life changing because I constantly change lines and colors although they are all coupled same (dotted has certain color and straight has certain colors). Didn’t know about favorites so hopefully it’s accessible . Thanks and will give update ☺️
cocoloco
ok I tested this and it Is sufficient! thanks
