Looking for a way to have different layout books
Rick Thompson
This might be unavailable in AC, but a need I have none the less.  The context is I am trying to make my business more user friendly for help not skilled in AC.  I have around 400 different PLN's I maintain and regularly send out PDF sets.  Essentially I send out 2 versions, on "for subs" marked "not for construction" and on "Permitting" without that statement.  Presently I have to seal my plans in NC, but that will end eventually.  They also need a "licensed to" filled in which is via auto text.  So, basically this is book publishing on demand in a few variations of each.
One solution is to simply save PDF sets of each, but the limitation is when something changes (say with a code date), they will not auto-update. (In AC all that info, including details is linked in an external file, so easy to change things).  The "licensed to" can be added in a PDF editor, as well as my seal when needed, so that is doable.  A code date could be changed too.
The cleanest solution would be to have duplicate Layout Books for each situation and set up in Publisher as different Sets.  Then someone (like my wife etc) could easily navigate to that and click and be done, no layer to deal with.  But, I can't find a way to have a Publisher set of the Layout Book with different layer combinations, and you can't have more than one Layout Book it seems.
Am I missing something, is this possible?  Thanks for any suggestions. I think making hundreds of PDF set is in my future.  There's a advantage to that too in that AC would not be needed at all.  I would also be exporting a DWG file as some people buy those.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
You can tell each subset to start at 1 again
that is the solution we use for contract and estimating sets.
Sub sets are your friend...
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
8 REPLIES 8
Gerry Leonor
the explanation to the context seemed difficult to read -- but perhaps it's different to how we mark drawings (here in australia).
unless i'm jumping the gun, you want to have 2 sets of layout books (as originally mentioned) where they have different Transmittal details & possibly some slight variation with the Drawing Master depending on the stage of the project that the drawing is in & who's receiving it?
i was going to suggest exporting the drawings from the model file into PMK files & import them into the 2 separate PLNs, each with their own Layout Book & Transmittal Details, this way, you can update as much as you want with the model file & publish the changes into 2 separate Layout Book PLNs with whatever project stage markings you need to show.
but you're already working with 400 PLNs to begin with. what i don't understand though is: do you have to be actively working on the 400 at the same time? or are you using the 400 PLNs as a template, grabbing 2 or 3 different ones for each client (4 / 6 Layout Book files) & put them into a separate project folder & never having to touch / edit the original 400 to begin with?
AC25 | Win11 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
I sell stock house plans, and "sort of" retiring and my grown kids will be sending out the plans.  It is an effort to simply so creating more files is not the direction I am aiming 🙂  They are basically static files except for adding to the plan who it is licensed to, and occasionally needing to update a few things, mostly code related (codes here are updated every 4 years or).  Most states do not care what it said "conforms to", but NC (North Carolina) does. NC required them to be sealed/stamped since I an an "architect".  Other than that, in the US house plans do not need to be sealed (well New Jersey).  I might just let my registration go, but in North Carolina it does help a plan reviewer approve a plan.  So it's not 400 plan at the same time, but most days I send out a plan, so they all do come around eventually.  It's actually around 200 plans, but most have a basement version so a different pln for that.
Thanks
Rick Thompson
Mac Sonoma AC 26
You can only have one layout book per file, but you can create as many layout subsets as you need.
Each subset can contain the same or different views to each other.
For example I have 'Sketch drawing' set that use views showing a simplistic sketch plan and elevations with reduced annotation layers.
And then I have a 'Working drawing' set that uses views for construction documentation.
I then have publisher sets for each and publish what I want when I want it.
Rick Thompson
Thanks for the suggestion.   I had tried that, and while it could work it would be a lot of work to get done what I need so so many plans.  Sub-sets change the sheet numbers (when set to auto) and to individually manually change those back w/out the prefix etc would be more than I am up for.
Thanks
Rick Thompson
Mac Sonoma AC 26
Also if you want auto text to say page 1 of 15 for the sub set 1 or page 1 of 7 for subset 2,
you have to a different master for each subset so you can have auto text for total number of layouts in that subset.
Insert autotext -> Number of layouts in subset -> Subset name
they have made it easier since Archicad 20 to do this.
Erwin Edel
If you can teach them how to make a transmittal set, you could use the transmittal set scheme for an autotext field that only needs to filled out or not:
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Hi Rick,
I have developed a tool using GDL that I think is fitting to your question. It's called SmartStamp, and the purpose is to be a customisable object that can be configured to react to the layout Transmittal History or any of the custom Layout property fields.
Here are some examples of the object configuration, which acts a a graphical key or legend of the settings when placed in the floorplans and as a dynamic stamp reacting to the conditions of the layout determined by the user when placed on a Master Layout. See screenshots below:
Archicad 28 ARM, MacBook Pro M3 Max 128Gb, macOS Sonoma.
/Operations Director /BIM Lead /Architect @ www.airc.digital ltd ™
M Architecture & Urbanism ARB
