NCS Wall Label 25 (AC USA), problems with text orientation
NCS Wall Label 25 is having problems with orientation, and ignoring ‘Always readable’. The problem remains on mirrored walls, and ‘Flip Label’ doesn't change this. The only sort of workaround I found was inverting the wall reference line direction. Is this a bug? Is there a simple way of fixing it on the script?
[Also, label doesn't really work with mirroring at all.]
NCS Wall Label 25 issues
5 Replies 5
Minh Nguyen
Hi Ignacio,
Thank you very much for the question!
After some tests, I believe this is not a bug, but just a limitation of the label. The same thing happens way back in Archicad 22.
What happened here is that the label orientation always follow the wall's direction. If you enable Wall & Beam Reference Line, you can see that the label follow the direction from left to right
When we mirror a wall, the direction also changes, thus the label is flipped.
To control the label orientation exactly, I suggest looking for this option in the Label Settings
I hope this helps you with the problem. Please let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Rene Pahlavan
Hi Minh--
Why can't the always readable function just be made to work in this important label? The above solution looks very bad on slanted walls.
AC28 (Apple Silicon)
macOS Tahoe 26.5
MBP M3 Max (16-inch 2023)
Rene Pahlavan
Looks like the same problem has persisted into AC26 - W-03 really looks strange upside down (see image).
macOS Tahoe 26.5
g r a n t
Agree. I can't get my head around these wall labels. It should be simple. Moreover, I can't even find the 26 version in my label list....??? G
I started learning ArchiCAD at age 50....bear with me,
AC29
MacBook Pro M1 Max.
Tahoe 26.5.1
Rene Pahlavan
Me too - same age 🙂
macOS Tahoe 26.5
