2022-02-16 08:35 PM - edited 2022-02-17 11:45 AM
NCS Wall Label 25 is having problems with orientation, and ignoring ‘Always readable’. The problem remains on mirrored walls, and ‘Flip Label’ doesn't change this. The only sort of workaround I found was inverting the wall reference line direction. Is this a bug? Is there a simple way of fixing it on the script?
[Also, label doesn't really work with mirroring at all.]
NCS Wall Label 25 issues
2022-02-22 06:58 PM
Hi Ignacio,
Thank you very much for the question!
After some tests, I believe this is not a bug, but just a limitation of the label. The same thing happens way back in Archicad 22.
What happened here is that the label orientation always follow the wall's direction. If you enable Wall & Beam Reference Line, you can see that the label follow the direction from left to right
When we mirror a wall, the direction also changes, thus the label is flipped.
To control the label orientation exactly, I suggest looking for this option in the Label Settings
I hope this helps you with the problem. Please let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-07-20 09:48 PM
Hi Minh--
Why can't the always readable function just be made to work in this important label? The above solution looks very bad on slanted walls.
2022-07-20 10:07 PM
Looks like the same problem has persisted into AC26 - W-03 really looks strange upside down (see image).
2023-06-08 07:26 PM
Agree. I can't get my head around these wall labels. It should be simple. Moreover, I can't even find the 26 version in my label list....??? G
2023-06-08 09:48 PM
Me too - same age 🙂
