2004-11-10 05:25 PM - last edited on 2023-05-19 10:26 PM by Gordana Radonic
2006-03-24 04:10 AM
Rick wrote:once it's set up, repeated publishing of PDF revisions to archive is made into a simple process.
I could not see any reason to publish to pdf. It requires more steps than a simple print to pdf (mac at least). Why bother?
2006-03-24 08:24 AM
Rick wrote:If you have a standard PlotMaker template set up, all you have to do is change the desitnation folder in the publishing set properties. All else is already set up.
2006-03-24 04:06 PM
2006-03-24 04:59 PM
2006-03-24 05:31 PM
RobertNichols wrote:What options are you setting to make a book? I have tried all I see, but must be missing something as all I get are pages.
Even on a Mac, I like publishing to PDF. You can get it to print to a book (not loose sheets) by selecting the right options.
2006-03-24 05:42 PM
2006-03-24 05:51 PM
TomWaltz wrote:HAAA now there's another obscure GS bit of info. If you don't drag the whole book over, you are not give that option!!!!
There is an option to combine into one book.
2006-03-24 06:23 PM
