2024-06-07
06:49 PM
2024-06-11
06:41 PM
trying to change the 1/A-302 text? can't seem to find this setting but both have been saved as views on layout SD12. if i go to SD12 both sections are correctly referencing the section layout in project map and view map.
Operating system used: Mac Intel-based Sonoma 14.4.1
Solved! Go to Solution.
2024-06-07 10:08 PM
Hi @Zdenko
Check section Marker symbol text settings, where you can change what is included in the second text row. Also marker refererence source can vary.
2024-06-07 10:08 PM
Hi @Zdenko
2024-06-07 11:15 PM
the marker symbol text interface was good but did go back to your link and found the solution. basically 2 options 1) the selected drawing or 2) first place drawing of selected view. it was an old layout i created and for some reason it retained the A-302 designation in my initial post v. the new layout designation SD12.
Thank you Ricardo Lopez!!!!
