Section ID
Zdenko
trying to change the 1/A-302 text? can't seem to find this setting but both have been saved as views on layout SD12. if i go to SD12 both sections are correctly referencing the section layout in project map and view map.
Operating system used: Mac Intel-based Sonoma 14.4.1
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
Ricardo Lopez
Hi @Zdenko
Check section Marker symbol text settings, where you can change what is included in the second text row. Also marker refererence source can vary.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Ricardo Lopez
Hi @Zdenko
the marker symbol text interface was good but did go back to your link and found the solution. basically 2 options 1) the selected drawing or 2) first place drawing of selected view. it was an old layout i created and for some reason it retained the A-302 designation in my initial post v. the new layout designation SD12.
Thank you Ricardo Lopez!!!!
Sequoia 15.1.1
Setup info provided by author
