LeeJaeYoung
What should I do with the stairs in the structural drawing?
In the structural drawing, the tread and riser should disappear first. How can this be done?
AC27 on window 11
5 Replies 5
Andrii Levko
Deselect "finish" in the stair settings dialog. Alternatively you can use Profile for riser and tread and select "Finish" for this components  in Profile Manager, and then select display "without finishes" in Partial Structure Display.
But as I have notice, it only works for 2D Sections and for 3D views, but doesn't works for 2D plans.
By the way, it would be nice if the Partial Structure Display had an impact on the display for 2D plans of the stairs structure as well.
Andrii
AC 8.1 - 28 INT/POL 3001
Win11
LeeJaeYoung
I'm working on version 25.
I don't understand, so please attach an image if possible.
If finish is off, tread & riser cannot be used.
AC27 on window 11
LeeJaeYoung
Are you saying it can't be done on a floor plan?
AC27 on window 11
Andrii Levko
You have to select  Profile Tread 25 in dialog settings and then apply your profile:
Step 1 and step 2
Then select "finish" for your component:
Step 3
But as I mentioned above, it only works for 2D Sections and for 3D views, but doesn't works for 2D plans:
Andrii
Win11
Andrii Levko
But remember, when you select "Without finishes", all components that have a "finish" marker in the project will disappear. So it is a solution for some simply cases only.
Andrii
Win11
