Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Where have my windows and doors gone?
designrevellion
I started drawing a renovation plan -- windows and doors were in the "existing" filter. They were still there in the "demolish" filter. I added new ones to the "new" filter. Then magically, they all disappeared. Any clues as to where they have gone? They show up on the door schedule, just not on the drawing.
~Anita (newby, no mentors, be kind please)
#designrevellion
10 REPLIES 10
Lingwisyer
Guru
Check your reno settings, as well as your MVO settings.
Hello, check my reno settings for what? The doors showed on every filter until recently. And what is an MVO, and a MVO setting?? ~Anita
#designrevellion
MVO = Model View Options.
You can hide the doors and windows in plan there as well.
Blair_C
Any chance your Floor Plan Cut Plane is above all your openings?
Blair Calvert
National BIM Manager, Cottee Parker Architects
ARCHICAD 4.5 to 27 | WIN10 i9 256GB RTX4000
Lingwisyer
Guru
Relevant if you have set your doors and window display to something other than symbolic.
thank you -- my doors are set as Symbolic on the floor plan display ~A
#designrevellion
Thank you Barry, my settings match what you've screenshot here... ~A
#designrevellion
If your doors are symbolic and the MVO is set to show doors, that is good.
Are the walls also set to symbolic?
They can be set otherwise, but the height of the Floor Plan Cutting Plane will come into effect.
Other than that, all I can think of it is the current renovation filter you are using.
You should have one called "Show All" ?
Apply that  and see what happens.
Thanks Blair, I changed my height to current storey to match yours (it was at 1150), but it didn't make a difference. I think I'm just going to delete my project and start again! ~A
#designrevellion
Setup info provided by author
