Why do I keep getting "Update to Frame"
dcerezo
Hey all,
I updated to AC 23 and I noticed that when I resize Drawings on my Sheets, I keep getting this "Update to Frame" or "Full Update" when I resize the frame. How do I turn that off? I don't remember this ever happening in AC22 and prior to that.
Thanks!
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
James B
Check this video on YouTube
It is a new feature of AC23 to reduce file size and improve performance.
James Badcock
16 REPLIES 16
James B
James Badcock
dcerezo
Thanks James!
Jeff Kogut
I need a global work environment setting to disable all this BS. It just slows down the process more than the 1.5 seconds it takes to rebuild the model. I'm not drawing Olympic stadiums over here.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
Jeff, maybe you should make a wish for this, in which you could explain the reasons why you think such an option should be implemented. Then we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration.
If you do make a wish, please post its link in this thread.
Did you ever make a wish for it?
I'm on your side Jeff.
AC 26, OS MONTEREY
James B
To turn off this crop feature, you can uncheck "Crop Drawing to Frame" in the Drawing Settings, under Frame.
James Badcock
So you can select all drawings in the Drawing Manager and turn this setting off for all of them at once.
Then don't forget to turn it off in the default settings for the drawing tool, then all new drawings you place will have the setting you want.
I'll check this out right away!
So much to learn.. 🙂
Thanks
AC 26, OS MONTEREY
@James B Slightly different take on this. I agree with @Jeff Kogut but I don't think the issue is how to turn off the cropping, I think it is something AC should manage automatically. AC should remove the need for user intervention. That way GS see the speed improvements and the user doesn't have to respond to disruptive questions. Every time I see this prompt the answer is Yes, so why ask?
