		2019-10-10
		01:38 AM
		2025-02-06
		11:14 AM
			Aruzhan Ilaikova
Solved! Go to Solution.
2019-10-10 06:15 AM
2019-10-10 06:15 AM
2019-10-10 02:48 PM
2020-04-01 05:43 PM
2020-04-05 09:05 PM
2022-03-30 09:37 AM
Did you ever make a wish for it?
I'm on your side Jeff.
2022-03-31 08:22 AM
To turn off this crop feature, you can uncheck "Crop Drawing to Frame" in the Drawing Settings, under Frame.
2022-03-31 09:13 AM
So you can select all drawings in the Drawing Manager and turn this setting off for all of them at once.
Then don't forget to turn it off in the default settings for the drawing tool, then all new drawings you place will have the setting you want.
2022-04-01 08:51 AM - edited 2022-04-01 08:53 AM
I'll check this out right away!
So much to learn.. 🙂
Thanks
2022-04-01 10:44 AM
@James B Slightly different take on this. I agree with @Jeff Kogut but I don't think the issue is how to turn off the cropping, I think it is something AC should manage automatically. AC should remove the need for user intervention. That way GS see the speed improvements and the user doesn't have to respond to disruptive questions. Every time I see this prompt the answer is Yes, so why ask?
