Zone Label comes with NCS wall label
Gisele
When I place a zone label, I also get a "separate" wall label that I can delete. Not sure how to restore the zone label.
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
2 ACCEPTED SOLUTIONS
JeffH
The additional label is most likely due to this option being selected
If you unclick that box, no additional label will be added.
If you want a specific different label, create and place whatever you want, and eye drop to pick up those parameters..
Next time you go to place a zone, it will place that label along with the zone/stamp.
AC24 / AC26 / AC27
Win10
What I think happens here is Gisele is placing a Zone with its Zone Stamp (the black one), and because of the setting JeffH refers to, a Label is also placed for the Zone. Probably a Wall Label is selected by default and this is why a Wall Label is placed along the Zone Stamp.
Gerry Leonor
not sure why 2 zones would appear, but out of curiousity, what Zone Stamp is currently called up in your Zone Category settings???
(Options > Attributes > Zone Categories)
AC25 | Win10 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
JeffH
AC24 / AC26 / AC27
Win10
