2023-06-02 05:30 PM
When I place a zone label, I also get a "separate" wall label that I can delete. Not sure how to restore the zone label.
Solved! Go to Solution.
2023-06-05 02:32 PM
The additional label is most likely due to this option being selected
If you unclick that box, no additional label will be added.
If you want a specific different label, create and place whatever you want, and eye drop to pick up those parameters..
Next time you go to place a zone, it will place that label along with the zone/stamp.
2023-06-09 12:45 AM
What I think happens here is Gisele is placing a Zone with its Zone Stamp (the black one), and because of the setting JeffH refers to, a Label is also placed for the Zone. Probably a Wall Label is selected by default and this is why a Wall Label is placed along the Zone Stamp.
2023-06-05 04:59 AM
not sure why 2 zones would appear, but out of curiousity, what Zone Stamp is currently called up in your Zone Category settings???
(Options > Attributes > Zone Categories)
2023-06-05 02:32 PM
2023-06-09 12:45 AM
