2024-05-28 06:33 PM
Hey, first sorry English is not my first language,
I am searching a way to simplified the 2D of a railing (l'élément "lisse" en français). Indeed I am working with a guardrail that has cables. Due to its small size, I want to represent it with only one line. But because it is an element, the software keeps putting two in order to delimit it. But hence it s size, in my blueprints (façade, coupe…) it s too much lines.
I tried to modify the object in itself, but I don't understand which thing I need to change in order to make its representation in 2D to be only a line.
Does anyone here know the this element here (view 3D)
in 2D, I need those two lines to be just a single line?
thanks in advence
Operating system used: Mac Apple Silicon 14.5 Sonoma
Solved! Go to Solution.
2024-05-28 10:49 PM
The facade view is a 2d representation of the 3d model.
If you want to represent the lines of the cables as one line, you will have to set diameter of the cable to almost 0 (e.g. 0.01).
The two lines will then overlap, leaving only one visible.
The disadvantage is that in the 3D model this is also displayed as one very thin line.
Workaround = duplicate railing, change settings and place them in different layers > seperate layercombination for different views.
2024-05-31 03:49 AM
Could you use a zero width pen for your wires? Or you could even set the contour to transparent (0)
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2024-05-28 10:49 PM
2024-05-31 03:49 AM
