2026-08-30 10:49 AM
I am not getting this intersection right. Both are with their default material properties.
is there any setting wrong? Please help Thank you
Solved! Go to Solution.
2026-08-30 01:12 PM
I am assuming that you modeled the "soil" using the Mesh tool.
Unfortunately, the geometry of a Mesh will not intersect automatically with other element types based on the Intersection Priority of its Building Material.
See more details here:
You will have to do it manually, using Solid Element Operations (SEO).
2026-08-30 01:12 PM
2026-08-30 06:09 PM
Thanks for the clarification.
