GDL
How can I get an override material for the wall?
LeeJaeYoung
I'm trying to get the override material for the wall from window & door.
AC27 on window 11
13 REPLIES 13
I am sure you have discussed this in other posts.
You need WALL_MAT_A, WALL_MAT_B, WALL_MAT_EDGE
But I think the values returned depend on how the window/door is placed in the wall - opening toward reveal side or not.
Lingwisyer
Guru
Following from Barry's, you can determine which side of the wall the door / window reveal was set to then flip WALL_MAT_A and WALL_MAT_B as required.
Win10 | R5 2600 | 16GB | GTX1660
Thank you for answer. ^^
Doesn't the 3D script take the master scripter's v... - Graphisoft Community
I've discussed WALL_MAT_A before.
The story progressed as a way to check because FLIPPED in 2D SCRIPT did not work in 3D SCRIPT.
And I also used WALL_MAT_A as a test, but the script didn't work, so I thought it didn't work.
That's why I posted a question, wondering if there might be something else.
I hope you understand. ^^
I have doubts about whether I need to change my mind about comparing the materials obtained in step 1 of WALL_SKINS_PARAMS. ????
I thought I would get the material index from the building material obtained in step 1 and compare it with WALL_MAT_A.
If I change the surface material like I did, is there a variable that will tell me what the value has changed?
In other words, is there a way to know when an icon was pressed and the material changed?
Thank you always for your consideration. ^^
Solved: Why is the default value of WALL_FLIPPED 1? - Graphisoft Community
I don't think I understood at this time.
I couldn't remember at all.
I think I just solved the question about the WALL_FLIPPED value.
sorry. ^^
I apologize for not being able to understand your in-depth explanation due to my limited skills.
Have a happy day.. ^^
AC27 on window 11
I would like to know how to know when this button has been pressed.
I'm asking this question because I think I need to know whether this button was pressed when comparing wall_mat_a with wall_skin_param.
AC27 on window 11
It is a boolean value.
If it is 0, the wall is not flipped.
If it is 1, the wall is flipped.
Are you referring to wall_flipped?
wall_flipped 3D script does not work properly.
And I want to know if that button is on/off.
AC27 on window 11
I thought you were talking about WALL_FLIPPED.
I have never actually used it but it is supposed to be usable in 3D.
This is not the same as the button for flipping in the windows and doors.
That I think is WIDO_REVEAL_SIDE.
Lingwisyer
Guru
From an object I was experimenting with.
IF SYMB_ROTANGLE = 180 then
		BUILDING_MATERIAL WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][18]							!Inside building material
		SECT_ATTRS{2} WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][9]
	else
		BUILDING_MATERIAL WALL_SKINS_PARAMS[1][18]											!outside building material
		SECT_ATTRS{2} WALL_SKINS_PARAMS[1][7]
endIF
	IF skin_return = "Custom" | skin_return = "Custom Inside" then
			gs_fw_side_left = gs_fw_side_left_i
			gs_fw_side_right = gs_fw_side_right_i
			gs_fw_upper = gs_fw_upper_i
			gs_fw_lower = gs_fw_lower_i
		ELSE
					gs_fw_side_left = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][2]
					gs_fw_side_right = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][2]
					gs_fw_upper = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][2]
					gs_fw_lower = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][2]
				else
					gs_fw_side_left = WALL_SKINS_PARAMS[1][2]
					gs_fw_side_right = WALL_SKINS_PARAMS[1][2]
					gs_fw_upper = WALL_SKINS_PARAMS[1][2]
					gs_fw_lower = WALL_SKINS_PARAMS[1][2]
			endIF
	endIF
	IF WIDO_REVEAL_SIDE = 0 then
			WALL_MAT = WALL_MAT_A
		else
			WALL_MAT = WALL_MAT_B
	endIF
I would like to know the function that determines whether this button has been pressed.
Even though I read it, I can't find that part.
Does this have anything to do with it?
WALL_SKINS_PARAMS
[19] skin edge surface index (considering wall edge surface override). Compatibility: introduced in ARCHICAD 22.
AC27 on window 11
