ā2019-02-13
05:28 PM
ā2022-09-26
10:57 PM
Daniel Kassai
Solved! Go to Solution.
ā2019-02-22 12:55 AM
ā2019-02-22 02:38 AM
Moonlight wrote:
8. PROJECT2{3} needs examples
ā2019-02-22 11:00 PM
ā2019-02-23 04:08 PM
Tips & tricks:
Working with CutpolyA (and variants) can be a little difficult to use since that there is no direct way to see them, especially when they don't give you the result that you wish.
But modifying the code to be prism_ compliant then by commenting the first line as seen in following example can make your work process a lot more easier ...
!cutpolyA 4, 3, 1,
prism_ 4, 1,
0.5, 0.5, 7,
0.75, 0.5, 7,
0.75, 0.75, 7,
0.5, 0.75, 7
ā2019-02-24 04:54 PM
ā2019-02-24 04:57 PM
ā2019-02-28 01:07 AM
ā2019-02-28 01:10 AM
ā2019-02-28 01:13 AM
ā2019-02-28 09:14 AM
Moonlight wrote:The API reference documentation is fine the way it is:
Graphisoft should start to ship it's API manuals as PDFs (2 to be accurate):
1. One for reference.
2. Second for first steps using API
