2019-02-13
05:28 PM
2022-09-26
10:57 PM
Daniel Kassai
Solved! Go to Solution.
2019-02-22 12:55 AM
2019-02-22 02:38 AM
Moonlight wrote:
8. PROJECT2{3} needs examples
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2019-02-22 11:00 PM
2019-02-23 04:08 PM
Tips & tricks:
Working with CutpolyA (and variants) can be a little difficult to use since that there is no direct way to see them, especially when they don't give you the result that you wish.
But modifying the code to be prism_ compliant then by commenting the first line as seen in following example can make your work process a lot more easier ...
!cutpolyA 4, 3, 1,
prism_ 4, 1,
0.5, 0.5, 7,
0.75, 0.5, 7,
0.75, 0.75, 7,
0.5, 0.75, 7
2019-02-24 04:54 PM
2019-02-24 04:57 PM
2019-02-28 01:07 AM
2019-02-28 01:10 AM
2019-02-28 01:13 AM
2019-02-28 09:14 AM
Moonlight wrote:The API reference documentation is fine the way it is:
Graphisoft should start to ship it's API manuals as PDFs (2 to be accurate):
1. One for reference.
2. Second for first steps using API
