GDL
Splitting Text in GDL
JeffH
We have our wall types all listed out like this in our composite list
- A _ Wall: MStud 6" Ins, Gyp.
In GDL, how would I strip out everything right of the "-" and then Left of the "_"
The end result needs to be " A ".
I am struggling to get the "WALL_COMPS_NAME" to work this way.
Any help would be greatly appreciated.
AC24 / AC26 / AC27
Win10
if strstr(WALL_COMPS_NAME,"-") > 0 and strstr(WALL_COMPS_NAME,"_")>0 then
   Start_num_pos = strstr(WALL_COMPS_NAME,"-") !!!!Postion in characters of first - character
   End_num_pos = strstr(WALL_COMPS_NAME,"_") !!!!Postion in characters of first _ character
   new_text_ = strsub(WALL_COMPS_NAME,Start_num_pos+1,End_num_pos-Start_num_pos-1)  !!!!!!!!Makes new string from first character after - to character before _
endif
this works in AC18, AC22 and AC25
I hope this will help
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft.
6 REPLIES 6
Yves
With this function …
STRSUB (string_expression, start_position, characters_number)
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
JeffH
the number is the part that won't work I believe. (We have a wall tag that is set up with exactly this method, that has been brushed aside for its limitations.)
sometimes we have a wall that is wall "A" to 8' , and wall type "D" above.
- A / D _Wall: MStud 6" Ins, Gyp.
"A / D" won't show correctly if I have this scripted to read the first 2 or 3 characters.  Id simply end up with "A /"
That is why I am trying to do a split to read everything between "-" & "_"
I have it working in properties & Classifications
But can't rely on calling that Unique ID for the property, because we have a few templates, so not every projects will have the same unique ID for the property that would be coded.
AC24 / AC26 / AC27
Win10
DGSketcher
Legend
Try the GDL function STRSTR to establish the position of "-" & "_", then apply those values to STRSUB as suggested by @Yves
endif
Lingwisyer
Guru
string = Bar_Scale1
len = STRLEN (string)
iDotPos = STRSTR (string, ":")
v1 = STRSUB (string, iDotPos + 1, 6)
v2 = SPLIT (v1, "%n", vl)
That is from my scale bar object.
AC22-28 AUS 3001Help Those Help You - Add a Signature
This is the solution we were after.
Thanks!!!!
Thank you all for your help in this matter.
AC24 / AC26 / AC27
Win10
