Apple MBP M2 MAX sucks.
Jimmy
my 2cents, hopefully this might save others time and money.
just bought a new mbp m2 max, it sucks, im returning it.
It doens't come close to my alienware x17r2 (i7 with rtx 3080 ti)
3d modeling is just terrible, where I spend a lot of time.
I didn't buy this machine for rendering.
27 REPLIES 27
I would guess it is a model issue again and not the Mac.
  • 4000'x4000' terrain with a lot of nodes
  • subtract 75 walls 400' long and 400' High
  • Time 10 seconds with 3 other ACs open.
As a test change the Intersection Priority (In Layers) of the elements you are using to subtract from the mesh
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Rotating 50 walls 6 seconds to rebuild
AC29 US/INT -> AC08
another Moderator
Adding 81 slabs (100'x100') and SEO with Upward extrusion ±50 sec
AC29 US/INT -> AC08
another Moderator
But AC25 running in emulation is only a little bit slower.
On another note an SEO of 75 walls is slower than the one for 81 Slabs.
AC29 US/INT -> AC08
another Moderator
Unabend
Thanks Mr. Stelvio :)))
Ok, Graphisoft Support send me an email, saying that the problem is yet the model not the Mac: 27,000 polygons in my Mesh it seems too much 🤔 ...but Apple say that my computer is INSANELY GREAT :))) WTF.........
Please, can you explain me how to interpretate your previous posts? Thanks!
I think if you buy the Quad Giulia and try to tow a cart with 200 bags of cement on it, the giulia might move a little slow, if at all, and it shouldn't be a surprise that your 0-60 time will suffer. 😁
AC29 US/INT -> AC08
another Moderator
Ok, but how many polygons does Archicad consider "many", "very many", "********" you idiot architect"? :))
I tried to install the Goodies containing the Polygon Count but for now I don't see it in the Palette list...
p.s. if I bought the Giulia Quadrifoglio I would warn you :))
The answer is that it depends. You always try to minimize or have to wait…
AC29 US/INT -> AC08
another Moderator
Ok... 27000 polygons is too much for Apple M2MAX...
But "max" what??? 👹
Or the problem is the "brain" of Archicad "apple silicon"...
The one above has 107,305 without issues on M1.
SO I would guess that there is something wrong with your Mesh or with your SEOs
AC29 US/INT -> AC08
another Moderator
