Crash when saving pdf
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-03-26 08:38 AM
2019-03-26
08:38 AM
My problem is when i try to publish pdf at one particular layout it crashes all archicad.
I don't know why now even when i open archicad it crashes instantly after opening.
I send report to graphisoft and this is the id: AC21-2019-02-27-13-57-13-3862, i saw that they asked to contact the local seller in Romania. I contacted it, they said they would look into it and responded vaguely on email that it works well in AC22. I said that i don't have AC22 only 21 in which i am currently working, 2-3 weeks since then and no response from them.
What should i do to make it open? Has this happened to anyone? What should i do with that code to find what's wrong, here in Romania i can't get help.
Thanks
Labels:
- Labels:
Performance
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-26 08:49 AM
2019-03-26
08:49 AM
I really don't know what the problem could be.
But I would try to 'open and repair' the file when you open the file from the 'open file' dialogue.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-26 08:56 AM
2019-03-26
08:56 AM
I tried that already, nothing changed..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-26 09:06 AM
2019-03-26
09:06 AM
drexdis wrote:If ARCHICAD is crashing as soon as it starts, I'd try reinstalling ARCHICAD first. If that doesn't help, I'd check if something is generally wrong with the computer, e.g. testing for a corrupted file system.
Ralph Wessel BArch
Central Innovation
Central Innovation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-26 09:24 AM
2019-03-26
09:24 AM
Maybe i was not explaining well. All other files are working well, only this project i am currently working on is crashing. Everthing is ok with other archicad file exporting, saving etc.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-26 09:29 AM
2019-03-26
09:29 AM
If local support can open it in AC22, ask them to save back to AC21 and send the file to you.
That's the quickest solution that I can think of.
Frustrating that this is their level of support though. Certainly not on par with what we have with the Dutch reseller (which has great support).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-03-29 11:21 AM
2019-03-29
11:21 AM
I asked a friend to save from 22 to 21 and be on floor plan view as you said, and now it is usable.
But the problem still existes when: i try to export ground floor plan on layout to pdf.
How do i find what is wrong with that layout that it keeps crashing when saving?
So, i am able to work in 2D, 3D, everywhere, only when saving that layout is crashing.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-04-08 03:53 PM
2019-04-08
03:53 PM
Thanks for posting your Bug ID, that actually helps a ton!
Based on the number I could check our system for the report and it turns out it points to a crash that we had already fixed in AC21 update 50xx (fix #232096). The latest build currently out for AC21 is 7000, and the report was sent from AC21 4022.
So, long story short: the issue is fixed in the latest update, so if you update your ARCHICAD to build 7000, the issue should be gone. It is always a good idea to check for updates if you experience an issue.
Let me know if the update helped!
Regards,
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
GRAPHISOFT
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-05-31 06:54 PM
2019-05-31
06:54 PM
Yes, that is true. I am on 4022 version not the latest. Thanks
