2024-01-20
03:47 PM
2024-10-12
07:06 AM
Does anyone know, how to get rid off that frame of the trees in 3D?
Thanks.
[Topic title edited by moderator to be more descriptive. Original title "Trees - ..it's urgent!"]
2024-01-20 10:33 PM
Hey there, first of all, you're posting in the German Forum (maybe @Claudius can move this topic!), secondly: You can use a GO since AC 25 for that (hiding contour lines).
2024-01-21 07:17 AM
You may already know this, but the outline will not show in the rendering, provided you use one of the Physical renderers.
2024-01-21 11:11 AM - edited 2024-01-21 11:17 AM
material "TreeMat3D"
!!!! Here You insert:
Pen YourPenName
!!!! End of Your insert
vert EPS, 0, EPS ! 1
vert A-EPS, 0, EPS ! 2
vert A-EPS, 0, _PicSize-2*EPS ! 3
vert EPS, 0, _PicSize-2*EPS ! 4
edge 1, 2, 0, 0, 0
edge 2, 3, 0, 0, 0
edge 3, 4, 0, 0, 0
edge 4, 1, 0, 0, 0
pgon{2} 4, 0, 0, 6,
-EPS, 0, 0,
1, 0, 0,
-EPS, 0, 1,
-EPS, 1, 0,
1, 2, 3, 4
body 1
del nTrans
end
2024-01-21
04:59 PM
2024-03-03
11:46 PM
I think if we want to modify the script 3D of the object then I will do like this
!!!!Old script
!!! edge 1, 2, 0, 0, 0
!!! edge 2, 3, 0, 0, 0
!!! edge 3, 4, 0, 0, 0
!!! edge 4, 1, 0, 0, 0
!!!!New script
edge 1, 2, 0, 0, 1
edge 2, 3, 0, 0, 1
edge 3, 4, 0, 0, 1
edge 4, 1, 0, 0, 1
2024-01-21 05:22 PM
Thats it! Easy!
You could, of course, give it an new parametername to switch it on/off it from the user-interface.
Thank You!
2024-01-22 12:17 AM
Trun off "Show Contours" in 3D Styles.
2024-03-02
04:09 PM
2024-03-03
11:48 PM
Thanks for the numerous answers... have now created an override technique for this tree, and displayed the "contour lines" here!
2024-11-05 12:58 PM
The trees "outline" contour lines are on Pen 4. So - although not ideal - you can retain the contours on the building and reduce the impact of the tree dark rectangle by changing Pen 4 to White or Light Grey.
